Brake Proportioning Valves
The True Story of a Misunderstood, Misused and Misnamed Brake System Component
http://www.stoptech.com/tech_info/wp_pr ... lves.shtml
Lisäksi tuota Stoptech info sivulta löytyy paljon tietoa jarruista ja jarrujärjestelmään liityvistä asioista.
Kannatta lukea jos olet yhtään huolestunut autoji jarruista.
Ei ole helpoa saada autoon lisää vauhtia mutta ei ole helpoa myöskään saada nopeaa autoa pysähtymään halutulla tavalla.
TECHNICAL WHITE PAPERS
Brake Technology
* The Physics of Braking Systems NEW
* Brake Bias and Performance: Why Brake Balance Matters
* Brake Systems and Upgrade Selections
* Rear Brake Upgrades, Is Bigger Really Better?
* ABS and Big Brake Kits Fundamentals, Impacts, and Real-World Solutions
* Formulas for Vehicle Braking Dynamics
Understanding Braking Experiences
* The "Warped" Brake Disc and Other Myths of the Braking System
* Pad Knockback: A Common Racing Phenomenon
Technical Guides
* Brake Pedal Setup and Dual Master Cylinder Installation Guide NEW
* Pad and Rotor Bed-In Theory, Definitions and Procedures NEW
* Removal of Uneven Pad Deposits From Rotors Using Aggressive Friction Compounds
* How to Bleed Brakes - The Right Way
* Bleeding ABS, is it really as hard as it sounds?
Braking System Components
* Brake Fluid 1A
* Monobloc Versus Two Piece Calipers
* Stainless Steel Brake Lines Q&A
* Brake Proportioning Valves: The True Story of a Misunderstood, Misused and Misnamed Brake System Component
Glossary
* Glossary of Braking Terminology
