sytytystulpat?
fast67
sytytystulpat?
Viesti Kirjoittaja fast67 »
Mitkä tulpat tulisi olla seuraavissa sylinterikansissa (esim. NGK tyyppikoodi)?
- 351W, Dart Windsor Sr. (Iron Cylinder Heads, intake port 197cc, Chamber Size 64cc, angle plug)
Voisiko noista tiedoista olla jotain apua?
Vai onko nuo kannet jotkut Dartin (http://www.dartheads.com)vanhat rautakannet?
Eikä World Products (http://www.worldcastings.com)
Technical Specifications of...
Windsor Jr. & Windsor Sr. Cylinder Heads
Material: High density cast iron
Valve Seats: Integral intake, hardened steel exhaust
Valve Guides: Integral cast iron
Valve Spring Seats: Machined for 1.250/1.550" springs (stepped)
Valve Size: 1.940" (Windsor Jr.) or 2.020" (Windsor Sr.) x 1.600"
Rocker Arm Studs: Accepts 7/16" screw-in studs
Exhaust Flange: Stock port locations. Dual bolt pattern accommodates large custom headers
Included In Base Assembly: Manley Street Flo (-1 models), or RaceMaster (-2 models)) forged stainless steel valves with swirl-polished heads, ring & band-style seals (-1/-2 models), valve springs, Manley 7° chrome moly retainers
Reommended Installation Items:
Rocker Arms: Aftermarket roller rocker arms recommended. However, if stock rockers are to be retained, use stud mounted rockers
Head Gaskets: Fel-Pro #9333PT (or #1011-2) or equivalent. Caution: #1011-1 is NOT recommended.
Pushrods: Requires heat-treated pushrods.
Spark Plugs: Accepts 14mm 5/8" reach tapered seat Accel 276 or equivalent
Intake Gasket: Fel-Pro #90361 or equivalent
Exhaust Gasket: Fel-Pro #1415 or equivalent
fast67
Jep, kyseessä on vanhat toimivat DART:n rautakannet. Ilmeisesti nuo World:n Windsor Sr. kannet vastaavat uudemmat painokset. Täytyypi kokeilla noita world:n kansiin speksattuja tulppia.
