takavalot
mustang cs 68
takavalot
Viesti Kirjoittaja mustang cs 68 »
tie täisikö joku kertoa että mistä on lainattu california mussen taka valot kun olisi tarvetta niille
Kimi
Viesti Kirjoittaja Kimi »
Googlettamalla löytyy mm. sivusto http://www.californiaspecial.com, josta oheinen suora lainaus:
"The tail lights too are shared with 68 Shelbys (67 Shelbys used Cougar tail lights), although they first appeared on 65 Thunderbirds. In order to fit these tail lights in the solid, concave rear panel on 68 Mustangs, Ford had to cut four additional holes in the sheet metal. A fiberglass cover panel was then placed over the rear so the new tail lights could be mounted. These lights required a special wiring harness which plugs into the stock Mustang pig tail leading to the trunk. The fiberglass rear panel is the same as the 68 Shelbys, however the wiring harness is completely unique to the GT/CS and HCS. This is one of the key areas to check when verifying a potential GT/CS or HCS."
- Kimi
Resto-Mod 1968 GT Convertible
