Mitenkä tämmöiset vanteet 65:n alla? Onko jollain vastaavia? Tuleeko jossain kohti ongelmia?
Rim Diameter (in): 15 in.
Rim Width (in): 7.00 in.
Backspacing (in): 4.750 in.
Offset (mm): +19.00mm
Lug Nut Seat Style: Conical seat
Wheel Construction: 2-piece
Conical Seat Taper: 60 degree
Hub Centric: No
Center Bore Diameter (in): 3.300 in.
Center Cap Included: No
Valve Stems Included: No
Recommended Valve Stem: 7/16 in. pull-through or bolt-on
Vanteet 65:seen
- 65HT
Vanteet 65:seen
Chrysler Sebring 2.7 2002
