HORSEPOWER & ACCELERATION
First, some useful info:
* One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower
than the first 4 rows at the Daytona 500.
* Under full throttle, a Top Fuel dragster engine consumes 1= gallons of
nitromethane per second; a fully loaded 747 consumes jet fuel at the
same rate with 25% less energy being produced.
* A stock Dodge 426 Hemi V8 engine cannot produce enough power to drive
the dragster's supercharger.
* With 3000 CFM of air being rammed in by the supercharger or overdrive,
the fuel mixture is compressed into a near-solid form before ignition.
Cylinders run on the verge of hydraulic lock at full throttle.
* At the stoichiometric 1.7:1 air/fuel mixture for nitromethane the
flame front temperature measures 7050 degrees F.
* Nitromethane burns yellow. The spectacular white flame seen above the
stacks at night is raw burning hydrogen, dissociated from atmospheric
water vapor by the searing exhaust gases.
* Dual magnetos supply 44 amps to each spark plug. This is the output of
an arc welder in each cylinder.
* Spark plug electrodes are totally consumed during a pass. After 1/2
way, the engine is dieseling from compression plus the glow of exhaust
valves at 1400 degrees F. The engine can only be shut down by cutting
the fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds up
in the affected cylinders and then explodes with sufficient force to
blow cylinder heads off the block in pieces or split the block in half.
* In order to exceed 300 mph in 4.5 seconds dragsters must accelerate at
an average of over 4G's. In order to reach 200 mph well before half-
track, the launch acceleration approaches 8G's.
* Dragsters reach over 300 miles per hour before you have completed
reading this sentence.
* Top Fuel Engines turn approximately 540 revolutions from light to light!
* Including the burnout the engine must only survive 900 revolutions
under load.
* The red-line is actually quite high at 9500 rpm.
* The Bottom Line:
Assuming all the equipment is paid off, the crew worked for free, and
for once NOTHING BLOWS UP, each run costs an estimated $1,000.00 per
second.
* The current Top Fuel dragster elapsed time record is 4.441 seconds for
the quarter mile (10/05/03, Tony Schumacher). The top speed record is
333.00 mph (533 km/h) as measured over the last 66' of the run (09/28/03
Doug Kalitta).
Putting all of this into perspective:
You are riding the average $250,000 Honda MotoGP bike. Over a mile up
the road, a Top Fuel dragster is staged and ready to launch down a
quarter mile strip as you pass. You have the advantage of a flying
start. You run the RC211V hard up through the gears and blast across the
starting line and past the dragster at an honest 200 mph (293 ft/sec).
The 'tree' goes green for both of you at that moment. The dragster
launches and starts after you. You keep your wrist cranked hard, but you
hear an i ncredibly brutal whine that sears your eardrums and within 3
seconds the dragster catches and passes you. He beats you to the finish
line, a quarter mile away from where you just passed him.
Think about it, from a standing start, the dragster had spotted you 200
mph and not only caught, but nearly blasted you off the road when he
passed you within a mere 1320 foot long race course.
That, folks, is acceleration.
Nitroputkissa on ky#pää. Jännää viedä ensikertalaisia esim. Alastaroon katsomaan nitroputken lähtöä. Itse virittelee sormia korviin ja katselee varovasti kavereiden ilmeitä ja eleitä kun yli 5000 hv jyrähtää burnikseen. Nyt kaverit tietävätä jo jotain voimasta, mutta paras on vielä jäljellä. Kun pre-stage ja stagevalot palavat ovat kummankin radat putket valmiina lähtöön. Vihreä kun välähtää niin se jytinä ja järinä on valtaisaa, sitä kiihtyvyyttä ei meinaa uskoa millään todeksi millä putket räjäyttävät itsensä yli maaliviivan. Jännää nähdä kun illalla tai oikeastaan pariin päivään ei kaverit muusta puhukaan kuin nitrodragstereistä. Blues Brothersia lainaten "do you see the light?" Kyllä jokaisen kuuluu kokea nitroputken lähtö, kuka sitä ei ole kokenut niin mars ensikesänä kiihdytyksen EM-kisoihin Alastaroon!
Ahti
Viesti Kirjoittaja Ahti »
Jep! Vuonna -97 olin toisissa Snap on Finalseissa, IHRA:n kisoissa, jenkeissä. Siellä näin elämäni ekat neloset. Oli aika haastavaa yrittää ottaa radan vieressä kuvaa kun tuntu että kameraa ei meinaa millään saada pidettyä kohteessa :lol:
Se on vaan tylsää kun top fuelin jälkeen alkaa tulemaan muita ryhmiä niin tuntuu että ne ei mene enää yhtään mihinkään ja tuntuu että vois lähteä oluttelttaan :shock: :D
Mustang GT -96
Fairmont -79 302/C4 FOR SALE!
Chevy Business Coupe -41
Buick Century Riviera 322 -55
Softail Heritage Classic -88
http://www.a-trukit.fi
Tarkkailija
Stock ja SuperStock autot ovat vallan mielenkiintoisia. Oluelle voipi lähteä kun mopot tulee viivalle. Kaikki kunnia nitroputkille, kuten edellä mainitaan, niissä on sitä oikeata m#naa.
Mussemaan
Mitenkähän tämä on laskettu?
"fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced"
Verrokkina tilanne jossa yhdellä nitrokoneella pyöritettäisiin potkuria joka liikuttaisi +360000kg massaa (paremmalla hyötysuhteella) 900km/h...jaa-a
Tapsa
Viesti Kirjoittaja Tapsa »
Joo... Nämä hevostelut ovat AIVAN OMAA LUOKKAANSA!
ns Isojen Poikinen tekniikan riemuvoitto, äänimailmakin
on kaukana tavanomaisesta papatuksesta
siksi tulet näkyvät päivälläkin putkista kun syöttöä
on enemmän kun ehtii palamaan
edelleen KULJETTAJILLE HATUNNOSTO kun kuula kestää moista
menoa ja väheksymättä yhtään MEKATSUJA jotka
purkaa joka vedon jälkeen tekniikan tarkastusta ja osien vaihtoa
varten
tunnen äijjiä jotka punnertaa putkien parissa
eivät paljon jaksa harrastaa muuten ruuvailua enää kuin kisoissa
siellä saa todella ruuvata lähes kellon ympäri että saadaan paketti
nippuun ajoissa seuraavaa vetoa varten
mutta suosittelen jokaiselle moottoripäälle käydä kisoissa
katsomassa ja kuuntelemassa kuinka kumi ja dynamiitti palaa :wink:
