Ennenkuin joku ennättää kysyä mitäs oljyä vanhaan Toploder askiin laitetaan ja kuinka usein öljyt tulisi vaihtaa niin tässä olkaa hyvä:
OILING SPECIFICATIONS
BREAK IN
Fill your Toploader with any quality 75W-90 gear lubricant until the oil level reaches the fill plug opening. It should take approx. 2 quarts. We recommend changing the gear lube for the first time between 500 and 1000 miles to remove the grease used to pack the needle bearings that has dissolved, Permatex, break in metal, glass beads etc. We use several new parts in our transmissions and they will seat in with each other during the break in period. It is not uncommon to see very fine metal on the magnetic drain plug when you drain the oil the first time.
MAINTENANCE
We recommend changing the gear lube every 20-25,000 miles in normal street driving applications. If you have higher than stock horsepower or drive your car aggressively you should change the gear lube every 10-15,000 miles. For stock type applications 75W-90 should work well in all climates. In heavy duty applications and hot climates 80W-140 will work best.
ROAD RACE TRANSMISSIONS
Toploaders used in racing applications need a break in period. Put some EASY laps on the transmission at low to mid rpm lightly accelerating and decelerating in each gear. This will give the gears a chance to break in and dissolve the grease in the needle bearings used during assembly. After a few laps, drain the transmission and clean the magnetic drain plug, then fill with 2 quarts of high quality gear lubricant. Once completed, the transmission should be race ready. 80W-140 seems to work best for competition applications. Change the gear lubricant after every race event.
SYNTHETIC GEAR LUBE
Synthetic oil is very popular in the automotive industry today. The way a Toploader is designed it needs a certain amount of friction for the blocker rings to synchronize shifts. We have had people try synthetics and say it works great and some say it doesn't work at all. Everyone agrees that standard gear lubricant does work. The biggest determining factor as to whether it will work or not is the driver. If you drive your car normally and shift it normally synthetic would be a great choice. If you drive aggressively or want to shift fast then synthetic may not work well. If you try synthetic gear lube and it does not work for your driving style drain the transmission and try standard 80W-140 gear lubricant.
Toploader öljyt
Toploader öljyt
mustang cs
niinpä
just tossa ilta päivällä ajattelin kysäitä tätä.pumppatessani perään 2litraa 75-90 öljyä. kuinka ollakkaan siinä touhutessani ajattelin muuten että, tarttis kysäistä 457:ta yv:n muodossa hiukan jeesiä??
Juu...
Itsellä kokemusta parista eri öljystä Toploaderin kanssa...
Mobil 1, synteettiset, liian liukkaat, ei pysy syncrot kehissä
Mobil 1, HD , hieman parempi, eli toimii, mutta voisi ottaa syncrot paremmin
Pennzoil 80w90, tämä öljy toimi mielestäni parhaiten näistä kokeilemistani. Mainittakoon vielä että tämä laatikko uusilla syncroilla, eli nyt 3000 ajetuilla.
