Spiff kirjoitti:Huom! ei mielellään epävarmoja ohjeita johon kuuluu sana "oikosulku" KIITOS!
No paperiliittimestä valmistetulla "erokoistyökalulla" minä tuon ohjelmoinnin tein ja oikosulku oli erottamaton osa toimenpidettä.
Mutta tässäpä virallinen ohje, pätee ainakin -97 asti.
Programming, Electronic Door Lock Control System
Note:
The remote keyless entry module erases all previous keyless entry remote
transmitters (15K601) from memory when thekeyless entry remote
transmitters are programmed or reprogrammed. The remote keyless entry
module can store up to fourkeyless entry remote transmitters in memory.
All keyless entry remote transmitters must be programmed (reprogrammed)
at the same time.
To program (or reprogram) keyless entry remote transmitter into the
remote keyless entry module, perform the following steps:
1. Turn ignition switch to RUN or ACC position and momentarily short the
two terminals of the Program Connector (two-pin connector next to the
remote keyless entry module. Remove LH luggage compartment trim panel to
reach the connector). Both doors should lock and then unlock. Remove
shorting pin.
2. Press any button on keyless entry remote transmitter. All front doors
should lock and then unlock to verify that keyless entry remote
transmitter has been programmed.
3. If door locks do not respond, press button again (up to three times
maximum with the same keyless entry remote transmitter). If door locks
still fail to respond, go to «Pinpoint Test A».
4. Repeat Step 2 to program additional keyless entry remote transmitters
into the remote keyless entry module (up to a maximum of four keyless
entry remote transmitters).
5. Turn ignition switch OFF. Both doors should lock and then unlock.
6. Check operation.
